Текущее время: 29 мар 2024 07:26
Начать новую тему  Ответить на тему  [ 31 сообщение ]  На страницу 1 2 3 След.
 Заголовок сообщения: Resin Casting Tutorial
СообщениеДобавлено: 21 янв 2013 15:06
Here are some photos from my book showing how to do resin casting.
1. These are som parts for a Tiger II engine. I break complex items into simpler parts as this make them easier to cast. I build a box around them and temporarily attach them with white PVA glue
2. I use kitchen scales to weigh the RTV rubber and catalyst.
3. After weighing the rubber, I add the catalyst.
4. Mix them thoroughly together until it is a uniform colour with no streaks.
5. For parts with lots of details, I use an old cheap brush to brush the rubber over the parts. This makes sure they are completely covered. For simple parts this is not neccessary.
6. Poor the rubber over the parts and fill the box to the top.
7. The resin – I use a 2 part resin that sets in 2 minutes (completely hard in 10 mins). This allows me to make many copies quickly but is best for small parts such as wheels – up to the size of a turret.
8. I measure the resin and quickly mix it together.
9. For parts with a lot of small detail, I brush the resin on with an old, cheap brush. This helps prevent air bubbles. A cocktail stick is sometimes useful to get the resin into the details. Bending the mould also makes it easier.
10. The rest of the resin is poured into the mould, up to the top.
11. Gently put a piece of rubber over the top to make a flat surface.
12. After 10 mins, pop the part out of the mould.
13. The piece needs a small amount of cleanup and is ready to use. (if there are bubbles, it is easy to try again!)
14. With clever design, very complicated shapes can be made.
С уважением Alex Clark
СообщениеДобавлено: 21 янв 2013 15:11
:shock: и всего делов то? :lol:
С уважением, Курочкин Виктор
СообщениеДобавлено: 21 янв 2013 15:18
Просьба к администрации форума, перенести тему в раздел: "Секреты мастерства", чтобы не потерялась. :wink:
Сложного не много, но вот таких материалов, у нас, за углом в каждой аптеке точно не купишь. :lol:
Я тут недавно сам поэкспериментировал с литьем, взял автогерметик (100% силикон в тюбике) и обычную ЭДП (эпоксидная смола), и откопировал себе детальку (пока простой формы). Получилось, хоть и с четвертого раза, но главное, я поверил в свои силы и возможности. :D
Спиридонов Павел.
СообщениеДобавлено: 21 янв 2013 15:23
Спасибо Алекс !
Жаль что данные компоненты не продаются у нас :(
С уважением Гуляев Алексей
СообщениеДобавлено: 21 янв 2013 15:33
Огромное спасибо, Алекс!
По моему, все настолько наглядно и очевидно, что и перевода не требует :wink:
Если кто не понял:
1. Алекс разбивает узел на более простые для литья компоненты, изготавливает коробку, временно приклеивает компоненты к днищу клеем ПВА.
2. На кухонных весах отмеряет герметик, вулканизирующийся при комнатной температуре, и катализатор.
3. Добавляет катализатор в герметик.
4. Тщательно перемешивает их до исчезновения цветных контрастных полос.
5. Если компонент сложен по форме, необходимо обмазать его герметиком со всех сторон. Алекс использует для этого старую дешевую кисть. При изготовлении компонентов простых форм, этот этап можно пропустить.
6. Заливает герметик в коробку доверху.
7. Смола. Двухкомпонентная. Начинает схватываться (?) через 2 минуты. Полностью застывает за 10 минут. Можно быстро изготовить множество копий, от мелочей, вроде колес, до крупных хреновин наподобие башен.
8. Затем Алекс отмеряет части смолы и быстро их смешивает.
9. Если отливаемая деталь сложной формы, старой дешевой кистью смола разгоняется по всем карманам. Таким образом можно избежать появления пузырьков. Иногда смолу удобнее заливать (ввиду особой формы деталей) с помощью соломинок для коктейля. Форму можно гнуть - это также упрощает процесс.
10. Остатки смолы заливаются в форму - доверху.
11. Сверху аккуратно кладется кусок резины (герметика) - для получения ровной плоской поверхности.
12. Через 10 минут извлекаем деталь из формы.
13. Немного чистим форму и используем ее еще раз (если в отливке есть пузырьки - повторяем до победного).
14. Все дело в правильной разбивке сложного узла на литые компоненты.
С уважением, Сергей Александров сын
СообщениеДобавлено: 21 янв 2013 15:56
I ordered mine online from a UK company (there are not many shops here that sell it):
http://www.sylmasta.com/acatalog/Castin ... aking.html
They also deliver international orders, but the postage would probably be expensive. Perhaps there are Russian hobby shops that might sell it?
СообщениеДобавлено: 21 янв 2013 18:03
Алекс спасибо огромное. Надо попробывать.
С уважением, Убоженко Дмитрий!
Танковые войска - главная ударная сила Сухопутных Войск!
СообщениеДобавлено: 21 янв 2013 21:49
osho79 писал(а):
Спасибо Алекс !
У нас, в особенности в Москве, не худшие компоненты продаются в Лассо, в Руте, в Сапфире, ну и в Пенте, конечно. В последней резина мне не очень по душе, а вот смолы вполне себе даже ничего.
Из резины мой личный выбор - Ласил-С (Лассо), хотя это дело вкуса.
Аниканов Денис Н.
СообщениеДобавлено: 21 янв 2013 22:06
И хочу обратить внимание вот на эти лезвия:
http://www.sylmasta.com/acatalog/Online ... 3_163.html
Это очень качественные лезвия, у нас они стоят многократно дороже. Очень хорошо держат заточку и поддаются правке,что увеличивает срок службы, в отличии от отечественных и китайских.
Вот для сравнения цены (для России VAT не применяется):
http://www.sylmasta.com/acatalog/Swann- ... ml#SID=163
http://www.sapphire.ru/vcd-415-1-4495/goodsinfo.html
Даже с прибавлением стоимости пересылки всё равно очень выгодно.
Аниканов Денис Н.
СообщениеДобавлено: 21 янв 2013 22:40
Хаха! так вот как это делается! Интересно. Спасибо.
Егор Владимирович
СообщениеДобавлено: 22 янв 2013 01:23
Всегда пожалуйста!
СообщениеДобавлено: 22 янв 2013 04:21
Спасибо Алекс !
Нового тут ничего нет для тех, кто хоть раз пытался отлить (Алекс это наглядно показал). Секрет только в качественных материалах. В России их найти маловероятно (Москва не счет)
Вопросы к Алексу (questions to Alex):
1. Материалы-специальные для моделизма или "общего" применения?
2. Оригинальные детали обрабатываете разделительным составом перед заливкой силиконом. Как справляетесь с шероховатостью оригинальных деталей?
3. Есть различия в клонировании Photoetcheds деталей, resin деталей относительно пластиковых деталей?
Зарание спасибо!
P.S. Просьба к коллеге Гамлету, если Алекс не поймет-помогите с переводом.
Александр Иванов
СообщениеДобавлено: 22 янв 2013 07:05
ИТР писал(а):
Спасибо Алекс !
Москва их отправляет по всей стране.
Аниканов Денис Н.
СообщениеДобавлено: 22 янв 2013 08:17
удалено
Последний раз редактировалось гарик М. 09 мар 2022 18:11, всего редактировалось 1 раз.
СообщениеДобавлено: 22 янв 2013 10:56
Alpha 6 писал(а):
ИТР писал(а):
Спасибо Алекс !
У нас второй месяц стоит -34. Я прошлой зимой заказал маскол-теперь есть красивая Ревелская баночка :D . К тому же химикаты навярняка отправлят транспортными компаниями-офисы их загородом (фиг добратся) и в субботу, воскресенье не работают :(
Александр Иванов
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 20 гостей
